Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
 AquaCraft V24 Gas Vee RTR Boat - Is this a good boat. >
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 01-30-2008 | 03:53 PM
  #76
Default RE: AquaCraft V24 Gas Vee RTR Boat - Is this a good boat.
just came back from running my whh man-o-war 45 min's of pure fun.....
Old 01-30-2008 | 04:05 PM
  #77
HPIGUY
OK.. if you feel that was a downright attack.. and its obvious you do… I can step up..
Please forgive me (Mike Zaborowski) for attacking your family… my apologies to you and yours.
Now can you?
Midgewich
Grimracer
Old 01-30-2008 | 05:06 PM
  #78
You alluded to or made accusations that because I was disappointed in how the V24 debacle was handled by Aquacraft and because I spout off about it that it somehow meant I must abuse my family, so yeah, it pissed me off.
But anyway, apology accepted, it's in the past now.
Happy boating.
Old 01-30-2008 | 07:08 PM
  #79
Go Electric,,Problems solved
Old 01-31-2008 | 07:14 AM
  #80
Good to see that everybody has made peace...... Life is too short for anything other than having fun.
Was just rebuilding my AC SV27 brushless after it got stuck in middle of the lake for 4 days..... Can't wait to run it again soon......
Old 03-14-2008 | 09:12 PM
  #81
Doby that is one sick boat and an excellent idea to make it electric. i have a v24 and i love the boat but i always have to putz with it. thanks for the pic,s and video and happy boating!
Old 05-05-2008 | 11:21 PM
  #82
Dang! That was a lot of unnecessary nonsense.
Now that that’s over...
Hi Everyone! I'm new to boating & I personally really like the v24.
Not as it is, but what it could be.
I think it’s one of the most original unique boats I’ve seen in a long time.
Even though it is... an old boat.
The real ones, $55,000+, gasp! Are way cool!
I have a question: As the title of this thread stated...
Is this boat a good boat? Well built?
Realistically… as in the hull, hardware, radio (witch I believe is a Futaba radio) excluding the Motor of course.
I’ve read the horror stories of the Rio’s motor.
I would be, (based on what I saw from doby’s electric conversion), very interested in having one.
I just love the hull design.
Is it possible to order one w/o the motor but with everything else?
I would even be happy to just display it on my coffee table until I can get a Zenoah for it.
Also. Is it possible to get 40- 50 mph from this hull without going too extreme? Engine wise.
I would be content with this boat if that were possible.
It’s just hard to spend $645.00 for this RTR boat, just to sink another $300.00ish, right into it before it even gets wet.
Thanks for the help.
Mikey
Old 05-11-2008 | 09:47 PM
  #83
[/quote]
Old 05-11-2008 | 09:50 PM
  #84
Old 05-11-2008 | 09:53 PM
  #85
Old 05-11-2008 | 09:54 PM
  #86
Old 05-18-2008 | 05:42 PM
  #87
for u v24 guys,.. got a chance to get close in person with this boat they said the blue runs 75 and the red goes 83 mph...enjoy..
ID:	952100   Click image for larger version
ID:	952101   Click image for larger version
ID:	952102   Click image for larger version
ID:	952103   Click image for larger version
ID:	952104   Click image for larger version
ID:	952105   Click image for larger version
ID:	952106   Click image for larger version
Old 05-19-2008 | 08:48 AM
  #88
XR Mikey; Here is a link to most of the parts you would need. The hulls show up on E-Bay everynow and then. Also, Tower sometimes has then in their "Scratch and Dent" section as well for good prices.
Its a fun boat and looks like nothing else on the water. It always draws a big crowd!
http://www3.towerhobbies.com/cgi-bin...I=AQUB40**&P=Z
Old 05-19-2008 | 11:35 PM
  #89
Thanks Doby.
How's your hull holding up so far?
Doe's it seem solid enough to last for awhile?
Mikey
Old 05-20-2008 | 11:14 AM
  #90
Its holding up very well, given that its faster than any gas powered V-24 out there. Earlier this year it hit 56.5 on the GPS.
I did how ever reinforce the hull with expandable foam in the bow, in the "wings" and under the radio box. Last fall it even survived a roll over at about 40 Mph with no problems.
Old 10-31-2008 | 12:55 PM
  #91
v24
Does any one know what prop you can changa to to get some more lift and speed out of a stock v24.
Old 11-01-2008 | 02:34 AM
  #92
I had a hairline crack on the cylinder head which was replaced with no question within a week and I live in Toronto, Canada. Oh yes we have igloos here
Get a Stainless Steel 3 Blade 70 Mil Tatur Prop
Get a Stainless Steel 3 Blade 68.5 Mil XXX Prop
from http://www.voodooprops.com
Want to plane higher and faster? Remove and replace your stock tank with an IV Bag and tuck it under your radio tray. This will give you better CG as the boat is nose heavy.
Want to turn better and faster? Fill in the space between strakes on the 3rd step and 2 inner strakes on the 2nd step. This will allow you to turn tighter without hooking or doing a barrel roll by being able to skim or slide over water in and out of tight turns. Do not grind off your strakes, the 8 Oz of fiberglass fill will give you a lower CG.
Put a Zen 260 PUM with clutch and water pump into it and you will have a big smile on your face. Add a CCP10 exhaust kit from http://www.ccracingengines.com and you will have one ear to ear.
When I grow up I will buy a Nimbus hull from MHZ with a Z drive or RCM drive.
Did I say I like my V24 then, now and in the future?
Old 11-02-2008 | 11:19 AM
  #93
Hi guys
My friend bought my V-24 off me.I changed the stock motor to a Sikk 27cc motor,wrap to centre manifold with a cmb tuned pipe.We ran the boat today in fairly rough conditions,handled it very well.We played with some props too.The best one we found was a Octura 455 3 blade.
Regards
Old 01-03-2009 | 11:02 PM
  #94
Hi I got my v24 and right out of the box i was missing small parts ..and the prop shaft set screw was so full of thread lock it striped out every one of my allen wrenches and then the screw.. and then loaded batteries in the receiver and the servos wouldnt even come on ..so i had no ready to run out of the box ,,,was very pissed by now ,bought from tower hobbies and they wanted me to wait and call aquacraft and i did and they had some girl on there and didnt even know what to do to help me ..and the dam radio box was cracked where they tightened the screws too tight ..so i had one hell of an experiance for the big money i paid for ...any one had that problem with the lower unit set srews so tight with thread lock on it ?....cause u are suppose to take it out after every run and greese it and does anyone use after run oil? please let me know ..ohh does there any water get in the back where that big opening is for the exhaust comes out of ?
Old 08-04-2010 | 07:17 PM
  #95
Hi boaters, im looking for the best prop for my V24 one , ive had the boat 2 years and run the boat in big water,only problem ive had so far is replaceing the  flex shaft other then that its been a reliable boat , anyway looking for the best prop for my boat need a little more speed and lift thanks again
Old 08-10-2010 | 01:15 AM
  #96
ORIGINAL: V24 1
I'm a local, you can get a new flex cable from Radio Controlled Sports as well as the WHH RMB703 or an Octura X470. The best CG for the V24 is where the kill switch is mounted so if you lift your boat with a loaded tank and it dips forward, replace the hard tank with an IV bag and place it under the engine. Happy boating...
Old 08-10-2010 | 05:28 AM
  #97
ok thanks i have 2 flex shafts on order should be in this week from radio controlled sports ..and thanks for the info on CG and prop
Old 02-04-2026 | 04:41 PM
  #98
So you did away with the cooling of the tuned pipe midway back?
