Tamiya Abrams 1/16 FO kit geometry >
Old 02-14-2026 | 12:05 PM
wsn123's Avatar
Default Tamiya Abrams 1/16 FO kit geometry
I have question - I noticed that the right side of my Tamiya Abrams is about 4-5mm lower than the left side - is it normal or any mistake?
Old 02-14-2026 | 04:13 PM
It’s probably normal - tank turrets are often not geometrically symmetrical aside from the obvious difference in cupolas, optics, etc. because the interior is not symmetrically laid out either.
Old 02-14-2026 | 07:36 PM
On torsion bar larger RC tanks like the Abrams it is not uncommon to have one side sit slightly lower than the other. 4-5mm is a lot of difference especially for a Tamiya Abrams. Both of mine sit pretty much level.
Old 02-15-2026 | 03:44 AM
wsn123's Avatar
Thank You guys for reply and help. Now Im wondering if I made any mistake in tank assembly - is it possible?
Old 02-15-2026 | 03:59 PM
Yes. It's possible the springs are installed incorrectly.
Old 02-15-2026 | 11:08 PM
I must correct myself as I misunderstood your question completely.
If the chassis is not sitting level then there is likely a mistake in assembling the torsion bars and suspension arms. However, all the torsion bars are the same part number so you may wish to check if parts are correctly fitted.
Old 02-16-2026 | 11:00 AM
wsn123's Avatar
Thank You very much for explanations
